Re: Update on my Puch
Ron Brown /
Dave,
You are right about the rusting but most gas tanks come right from the factory with no plating inside. If you use the vehicle regularly and keep gas in it, corrosion does not seem to be a big problem. This is especially true if you use premix.
It does not hurt, to try to use gas with 10% alcohol from time to time, or add a little dry gas to remove any water that finds its way into the tank.
Ron
  Update on my PuchTopic by: Brandon E Brandon E 03/05/01 11:45PM
  Re: Update on my PuchRe: Miguel Miguel 03/06/01 02:51AM
  Re: Update on my PuchRe: Ron Brown Ron Brown 03/06/01 10:46AM
  Re: Update on my PuchRe: Brandon E Brandon E 03/06/01 12:45PM
  Re: Update on my PuchRe: Ron Brown Ron Brown 03/06/01 01:39PM
  Re: Update on my PuchRe: daveb daveb 03/06/01 03:23PM
  Re: Update on my PuchRe: Ron Brown Ron Brown 03/06/01 03:36PM
  Cuising the drivewayRe: Brandon E Brandon E 03/06/01 11:44PM
  Re: Cuising the drivewayRe: Miguel Miguel 03/07/01 12:03AM
  Re: Cuising the drivewayRe: Ron Brown Ron Brown 03/07/01 09:55AM
  Re: Cuising the drivewayRe: Brandon E Brandon E 03/07/01 12:37PM
  Re: Cuising the drivewayRe: Ron Brown Ron Brown 03/07/01 12:58PM
  Re: Cuising the drivewayRe: Brandon E Brandon E 03/07/01 01:22PM
  Bowling for (no) dollars.Re: Fred Fred 03/07/01 06:34PM
  Re: Bowling for (no) dollars.Re: Brandon E Brandon E 03/07/01 06:51PM
  Re: Bowling for (no) dollars.Re: Fred Fred 03/07/01 07:12PM
  Re: Bowling for (no) dollars.Re: Brandon E Brandon E 03/07/01 07:31PM
  No Lead neededRe: Fred Fred 03/07/01 07:06PM
  Re: No Lead neededRe: Ron Brown Ron Brown 03/07/01 08:22PM
  Stee-rike!Re: Brandon E Brandon E 03/07/01 08:45PM
