Re: I'm starting to hate my 'ped.
Fred /
First of all... You should tell us which ped it is. What year?. Mileage?
(but as I remember it it is a Euro... so I am not an expert on them)
And I am glad you are a wrench for a living.
And I am almost surprised that you need help.
But..... here goes.
I have never seen a small engine that has to have a fully charged battery to run.
On most of them the battery really only has 3 functions...
1st... as a large voltage regulator (and that is whether it is alive or dead) to keep light bulbs from blowing at high revs.
2nd... to keep the lights from going too dim at idle speeds at night.
3rd... to spin the electric start (if it has one)
So I can say you can rule out the battery as a source of trouble (dead or alive).
You said the oil pump might be on the fritz... bad news.
Why do you say this?
Has the oil level stayed the same for months?...bad news.
But they don't drink a whole lot of oil either.
But if the oil system failed a month ago... no amount of oil will now "fix it".
You say you removed the head and scraped off carbon... OK....
But did you push the piston to BDC and look (with GOOD light) for scoring and scuffing down in the cylinder?
You could have ruined the ring seal by starving it for oil without getting an actual seizure.
If this is a ped with the exposed head and cylinder.... pull the cylinder right off (easy as can be) and take a close look at the piston skirt and look for heavy scuffing... and even aluminum from the piston smeared over the rings.
If that is the case you need an oversize piston and rings and a bore job.
And toss the oil pump and premix it.
Also... put the piston in the cylinder and stick a feeler guage in between them (the piston should be in the BDC position while you do this measurement)....What is the clearance?
Also... You said you cleaned the carb... That means you used 100 psi of compressed air thru all orifices many times?
While you have the cylinder off play with the rod and look for evidence that the rod bearing or crank bearings are gone.
Push it, pull it, spin it... you are looking for too much friction, stiff spots, funky noises, too much play.
You of course have the proper spark plug?
  I'm starting to hate my 'ped.Topic by: david f martin david f martin 03/05/01 09:48PM
  Re: I'm starting to hate my 'ped.Re: Miguel Miguel 03/05/01 11:01PM
  simply your mechanic approachRe: Miguel Miguel 03/05/01 11:17PM
  Re: simply your mechanic approachRe: Doug D Doug D 03/05/01 11:57PM
  Re: simply your mechanic approachRe: Jim C. Jim C. 03/06/01 12:18AM
  Re: simply your mechanic approachRe: Doug D Doug D 03/06/01 12:59AM
  Re: simply your mechanic approachRe: david f martin david f martin 03/06/01 12:35AM
  Re: I'm starting to hate my 'ped.Re: Fred Fred 03/06/01 12:17AM
  Re: I'm starting to hate my 'ped.Re: david f martin david f martin 03/06/01 12:56AM
  Re: I'm starting to hate my 'ped.Re: Fred Fred 03/06/01 02:21AM
  Meant to askRe: Fred Fred 03/06/01 02:22AM
  Re: Meant to askRe: Miguel Miguel 03/06/01 02:45AM
  Re: I'm starting to hate my 'ped.Re: Ron Brown Ron Brown 03/06/01 11:00AM
  Re: I'm starting to hate my 'ped.Re: Reeperette Reeperette 03/06/01 02:16PM
  Re: I'm starting to hate my 'ped.Re: david f martin david f martin 03/06/01 08:30PM
  Get a Divorce !Re: dave2 dave2 03/08/01 03:58PM
  Re:Give it a enema and aspirinRe: DOUG D DOUG D 03/08/01 04:03PM
  Re:Give it a enema and aspirinRe: Ron Brown Ron Brown 03/08/01 05:20PM
