Re: motobeacan condensor is this it?
Tri-ped Dave O.D.B. /
Motobecane flywheels are a joy. First you remove the Novi nut with the correct tool (or you usually chew up the slots). It is almost always frozen on there. Then you should use a proper flywheel puller. The condenser is under the fly wheel on the bottom right corner.
