motobeacan condensor is this it?
also how do i pull off fly wheel?
Re: motobeacan condensor is this it?
Tri-ped Dave O.D.B. /
Motobecane flywheels are a joy. First you remove the Novi nut with the correct tool (or you usually chew up the slots). It is almost always frozen on there. Then you should use a proper flywheel puller. The condenser is under the fly wheel on the bottom right corner.
http://www.mopedarmy.com/wiki/Guide_to_Motobecane_spark_and_timing
this will help you get that cover off.
sometimes the condenser is on the back side of the stator plate too
Bottom line is try and find a friend with a Moby that has the proper tools so you do not create a bigger mess by chewing up the Novinut or worse.
just remember the novi nut is REVERSE THREADED.
why can't you just use a rachet with no socket on it on the novi nut.
