Re: Bent Rim
Ron Brown /
For the bent rim, remove the tire and try to use blocks of wood and a large bench vise to press it back into shape. You do not need to ose blocks which are shaped to fit the wheel, just try to suppert it where it is ok and apply pressure to the center of the kink. Go slowly, if the wheel cracks, replace it.
For the cracked rim, if it is still true, check it regularly and either replace it or have it welded if it spreads.
For future pot holes, if you can think of it and react in time, stand on the pedals with your knees bent and try to tug up on the handlebars as if you were climbing a kerb.
Ron
  Bent RimTopic by: Ataristyle Ataristyle 03/02/01 01:00AM
  Re: Bent RimRe: daveb daveb 03/02/01 01:33AM
  Re: Bent RimRe: Reeperette Reeperette 03/02/01 12:38PM
  Re: Bent RimRe: Ron Brown Ron Brown 03/02/01 09:49AM
  Re: Bent RimRe: Ataristyle Ataristyle 03/02/01 02:42PM
  Re: Bent RimRe: Reeperette Reeperette 03/05/01 10:54AM
  Re: UnBending Rim Story(Pics)Re: Ataristyle Ataristyle 03/06/01 01:24AM
  Re: UnBending Rim Story(Pics)Re: Ataristyle Ataristyle 03/06/01 01:25AM
  Re: UnBending Rim Story(Pics)Re: gimmejimmie gimmejimmie 03/06/01 10:30AM
  Re: UnBending Rim Story(Pics)Re: Ataristyle Ataristyle 03/06/01 02:34PM
  Re: UnBending Rim Story(Pics)Re: Ataristyle Ataristyle 03/06/01 11:27PM
