Re: Gas is now stored in a baking pan - please hel
gimmiejimmie /
Carrie,
I couldn't resist that last post of mine about the mug,but seriously now , check the on / off valve where it screws into the gas tank and trace the fuel line down to the carb., if that part is dry, then you have a stuck needle valve inside your carb and should be repaired by someone qualified. Leaking gas indoors is a killer!
