Re: Biggest tires that fit on a stock maxi
This was covered all ready in this thread break>
There are pics in there of a Pinto w/2.5" IRC on the rear and a Magnum swingarm on a pinto w/3.0" Gazzele; but here is that pinto again (it's not a fluck I have 2 that are set-up identical except for the gearing).
FYI...a maxi is a maxi is a maxi unless it's rigid, all years are the same.
Your math is screwed up there Andrew, 10 tires at 16.72 and 10 tubes @ 3.28 does not equal $113, might want to check the quantities on that order.
And yes they 2.5 will wedge into the swingarm on install, just let out the air, then you have to run your chain long enough to run the tire almost all the way back in the slots.
  Biggest tires that fit on a stock maxiTopic by: SABAT! andDestroy SABAT! andDestroy 11/25/08 06:48PM
  Re: Biggest tires that fit on a stock maxiRe: derek derek 11/25/08 07:03PM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 12:47AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/25/08 07:15PM
  Re: Biggest tires that fit on a stock maxiRe: SABAT! andDestroy SABAT! andDestroy 11/25/08 07:16PM
  Re: Biggest tires that fit on a stock maxiRe: Moped Jay Moped Jay 11/25/08 07:17PM
  Re: Biggest tires that fit on a stock maxiRe: SABAT! andDestroy SABAT! andDestroy 11/25/08 07:23PM
  Re: Biggest tires that fit on a stock maxiRe: Brian Brian 11/25/08 07:36PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/25/08 07:42PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/25/08 07:46PM
  Re: Biggest tires that fit on a stock maxiRe: derek derek 11/25/08 07:59PM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 12:41AM
  Re: Biggest tires that fit on a stock maxiRe: Calvin Calvin 11/25/08 08:15PM
  Re: Biggest tires that fit on a stock maxiRe: Moped Jay Moped Jay 11/25/08 10:19PM
  Re: Biggest tires that fit on a stock maxiRe: paulvolio paulvolio 11/25/08 08:27PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/25/08 08:35PM
  Re: Biggest tires that fit on a stock maxiRe: SABAT! andDestroy SABAT! andDestroy 11/25/08 09:34PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/25/08 09:56PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/25/08 09:58PM
  Re: Biggest tires that fit on a stock maxiRe: Calvin Calvin 11/25/08 11:16PM
  Re: Biggest tires that fit on a stock maxiRe: Ponyboy MP Ponyboy MP 11/25/08 11:19PM
  Re: Biggest tires that fit on a stock maxiRe: jason jason 11/25/08 11:33PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/25/08 11:42PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 12:04AM
  Re: Biggest tires that fit on a stock maxiRe: derek derek 11/26/08 12:10AM
  Re: Biggest tires that fit on a stock maxiRe: Ponyboy MP Ponyboy MP 11/26/08 12:13AM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 12:16AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 12:15AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 12:18AM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 12:25AM
  Re: Biggest tires that fit on a stock maxiRe: Ponyboy MP Ponyboy MP 11/26/08 12:26AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 12:32AM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 12:35AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 12:35AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 12:48AM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 12:51AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 12:57AM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 01:00AM
  Re: Biggest tires that fit on a stock maxiRe: Ponyboy MP Ponyboy MP 11/26/08 12:59AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 01:05AM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 01:10AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 01:16AM
  Re: Biggest tires that fit on a stock maxiRe: Daniel Van Donsel Daniel Van Donsel 11/26/08 01:21AM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 01:58PM
  Re: Biggest tires that fit on a stock maxiRe: derek derek 11/26/08 02:05PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 02:16PM
  Re: Biggest tires that fit on a stock maxiRe: elliot elliot 11/26/08 02:34PM
  Re: Biggest tires that fit on a stock maxiRe: elliot elliot 11/26/08 02:35PM
  Re: Biggest tires that fit on a stock maxiRe: derek derek 11/26/08 03:03PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 03:58PM
  Re: Biggest tires that fit on a stock maxiRe: derek derek 11/26/08 04:53PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/26/08 05:22PM
  Re: Biggest tires that fit on a stock maxiRe: andrewhed andrewhed 11/27/08 12:57PM
  Re: Biggest tires that fit on a stock maxiRe: jason jason 11/30/08 10:20AM
  Re: Biggest tires that fit on a stock maxiRe: camgregus camgregus 11/30/08 04:01PM
