Re: Phosphoric acid
Brandon E /
I'll check that out.
I thought of another question:-)
Brandon E /
How tight should the engine chain be? Once again, thanx for all the help, everyone!
Re: Phosphoric acid
Ron Brown /
I'll check out the thermalized soup :-)
Ron
Re: I thought of another question:-)
Ron Brown /
Brandon,
You have exceeded your quota of questions for 2001.
ALL POSTS UNTIL 1-1-2002 WILL BE DELETED!
Just kidding. As long as your chain has some slack you are ok. If you have rear suspension, compress it unitl the two sprockets and the swingarm pivot all line up. This is the maximum distance between the sprockets. If you are working alone, use a tie down or something similar to compress the suspension. Then spin the back wheel slowy and watch the chain. If it has a tight spot, replace it or back off on the adjusters a bit until the tight spot has a little play then live with this adjustment for the rest of the chain.
Ron
