Re: Adventures of a Consumer
Ron Brown /
Brandon,
As they say, this changes everything.
In order to use Kreem, you have to "slosh" it around to spread out the coating on the inside of the tank. I suspect that you may find this difficult to do unless you strip the ped to the frame. It probably would be light enough to toss around then.
I would stick with the acid only approach. I do not know where you live, but most buisinesses using large stainless steel vessels also use Phosphoric acid. Dairy farmers, dairy products, brewerys etc. Posibly you could call one, or just stop by, it is cheap and they may just give you some.
Whem you use it, you are going to have to figure out how to get it back out of the tank safely. Typically, with a removable tank, you can just duct tape over the holes and dump it by removing the tape. You must remove the petcock and removing the gas cap is a good idea as it has a vent hole which can leak acid.
If the petcock scews into a threaded hole in the tank, maybe you can find a brass nipple that will fit the thread and allow you to drain the acid safely. If you have no choice but tape, remember that a running hose is your best defense against disaster.
For all of the following, keep a garden hose available and turned on. Wear old clothes, there is a good chance they will become religious, as in holey. Work outside, away from anything which could get splashed. When rinsing, use a lot of low pressure water, high pressure will send acid to places where it may do damage before you find it.
When you get the acid, mix some up in a plastic container and test it with a piece of rusty steel. You want it to remove the rust in about ten minutes but you are not looking for a violent reaction.
Remove the petcock and plug the hole with something appropriate, good duct tape usually works. Remove the gas cap if possible, if not, cover the hole with saran wrap before closing the cap to keep the vents from filling with acid.
Pour enough diluted acid in the tank to almost fill it. Seal the filler with tape or the cap/saran wrap and slosh the acid so that it is cleaning the top side of the tank. Just rocking the bike will do this. Keep an eye open for leaks and rinse off any acid you see immediately with a slow hose. Keep sloshing every minute or so until your time is up as determined by the test above, then slosh and wait five minutes more.
I am not sure how you are going to drain the tank but if you have not figured out a drain tube, lean the ped so most of the acid will fall straight to the ground and keep a sready flow of water on the hose to rinse any parts of the ped which get splashed.
Btw, letting the acid run into the ground in your yard is not an ecological disaster. Many plants prefer acidic soil. Don't let your pets get near it, dilute it a lot and don't dump it all in one place, especially not at the base of a tree.
Check the inside of the tank to make sure you do not need another application.
Using a rinse and slosh tecnique, get rid of all the acid in the gas tank then dry off the ped. If you have an air line, blow out the tank. If not, dry it as well as you can with rags, paper towels, hair dryer etc. Then replace the petcock and pour a bottle of "dry gas" into the tak and close the lid. Slosh this around for a few minutes to mix with any remaining water trapped in the tank seams, then drain it out.
Add gas and ped away.
Most hardware stores sell a good selection of plastic tubing and have an explaination of what liquids they are resistant to.
Ron
Ron
  Engine bog and Front BrakesTopic by: Brandon E Brandon E 02/15/01 03:54PM
  Re: Engine bog and Front BrakesRe: Fox Fox 02/15/01 06:58PM
  Re: Engine bog and Front BrakesRe: Rasta Rasta 02/15/01 09:13PM
  Re: Engine bog and Front BrakesRe: Brandon E. Brandon E. 02/15/01 10:29PM
  Hold onRe: Fred Fred 02/16/01 12:39AM
  Re: Hold onRe: Brandon E Brandon E 02/16/01 05:11AM
  Re: Engine bog and Front BrakesRe: Ron Brown Ron Brown 02/16/01 09:33AM
  Re: Engine bog and Front BrakesRe: mike mike 02/16/01 02:50PM
  Re: Engine bog and Front BrakesRe: Ron Brown Ron Brown 02/16/01 05:16PM
  Another QuestionRe: Brandon E Brandon E 02/16/01 03:31PM
  Re: Another QuestionRe: moby moby 02/16/01 05:50PM
  Re: Another QuestionRe: Fred Fred 02/16/01 06:37PM
  Re: Another QuestionRe: Brandon E Brandon E 02/16/01 06:55PM
  Re: Another QuestionRe: Ron Brown Ron Brown 02/17/01 10:27AM
  Re: Another QuestionRe: gimmejimmie gimmejimmie 02/16/01 06:54PM
  what's happened thus farRe: Brandon E. Brandon E. 02/18/01 10:29PM
  Re: what's happened thus farRe: gimmejimmie gimmejimmie 02/18/01 10:40PM
  Re: what's happened thus farRe: Ron Brown Ron Brown 02/19/01 10:36AM
  Re: what's happened thus farRe: Brandon E Brandon E 02/19/01 06:18PM
  Pictures of my machinesRe: Brandon E Brandon E 02/19/01 06:23PM
  Re: Pictures of my machinesRe: Ron Brown Ron Brown 02/19/01 07:00PM
  Adventures of a ConsumerRe: Brandon E Brandon E 02/19/01 08:19PM
  Re: Adventures of a ConsumerRe: Reeperette Reeperette 02/20/01 06:28AM
  Re: Adventures of a ConsumerRe: Ron Brown Ron Brown 02/20/01 10:58AM
  Sorry, RonRe: Brandon E Brandon E 02/20/01 02:31PM
  Re: Sorry, RonRe: Ron Brown Ron Brown 02/20/01 05:02PM
  Dry Gas?Re: Brandon E Brandon E 02/20/01 06:02PM
  Re: Dry Gas?Re: Ron Brown Ron Brown 02/20/01 08:44PM
  Re: Dry Gas?Re: Brandon E Brandon E 02/20/01 09:44PM
  Phosphoric acidRe: Michael Michael 02/21/01 05:02PM
  Re: Phosphoric acidRe: Brandon E Brandon E 02/21/01 08:02PM
  Re: Phosphoric acidRe: Ron Brown Ron Brown 02/22/01 11:01AM
  I thought of another question:-)Re: Brandon E Brandon E 02/21/01 08:23PM
  Re: I thought of another question:-)Re: Ron Brown Ron Brown 02/22/01 11:11AM
