Re: Another Question
Ron Brown /
Brandon,
I have cleaned several gas tanks using muriatic acid solution, available cheap at any hardware store. I have since found out that Phosphoric acid is better because it does not promote rust and actually leaves a protective surface by some chemical reaction. Apparently, it is axailable at farm stores because it is used to clean stainless steel milking equipment.
If you are using the bike regularly, you do not realy need the kreem coating, fuel seems to prtect the tank, especially if you are using gas/oil mix.
You may want to surf some of the vintage motor cycle sites, they talk about this a lot.
Ron
  Engine bog and Front BrakesTopic by: Brandon E Brandon E 02/15/01 03:54PM
  Re: Engine bog and Front BrakesRe: Fox Fox 02/15/01 06:58PM
  Re: Engine bog and Front BrakesRe: Rasta Rasta 02/15/01 09:13PM
  Re: Engine bog and Front BrakesRe: Brandon E. Brandon E. 02/15/01 10:29PM
  Hold onRe: Fred Fred 02/16/01 12:39AM
  Re: Hold onRe: Brandon E Brandon E 02/16/01 05:11AM
  Re: Engine bog and Front BrakesRe: Ron Brown Ron Brown 02/16/01 09:33AM
  Re: Engine bog and Front BrakesRe: mike mike 02/16/01 02:50PM
  Re: Engine bog and Front BrakesRe: Ron Brown Ron Brown 02/16/01 05:16PM
  Another QuestionRe: Brandon E Brandon E 02/16/01 03:31PM
  Re: Another QuestionRe: moby moby 02/16/01 05:50PM
  Re: Another QuestionRe: Fred Fred 02/16/01 06:37PM
  Re: Another QuestionRe: Brandon E Brandon E 02/16/01 06:55PM
  Re: Another QuestionRe: Ron Brown Ron Brown 02/17/01 10:27AM
  Re: Another QuestionRe: gimmejimmie gimmejimmie 02/16/01 06:54PM
  what's happened thus farRe: Brandon E. Brandon E. 02/18/01 10:29PM
  Re: what's happened thus farRe: gimmejimmie gimmejimmie 02/18/01 10:40PM
  Re: what's happened thus farRe: Ron Brown Ron Brown 02/19/01 10:36AM
  Re: what's happened thus farRe: Brandon E Brandon E 02/19/01 06:18PM
  Pictures of my machinesRe: Brandon E Brandon E 02/19/01 06:23PM
  Re: Pictures of my machinesRe: Ron Brown Ron Brown 02/19/01 07:00PM
  Adventures of a ConsumerRe: Brandon E Brandon E 02/19/01 08:19PM
  Re: Adventures of a ConsumerRe: Reeperette Reeperette 02/20/01 06:28AM
  Re: Adventures of a ConsumerRe: Ron Brown Ron Brown 02/20/01 10:58AM
  Sorry, RonRe: Brandon E Brandon E 02/20/01 02:31PM
  Re: Sorry, RonRe: Ron Brown Ron Brown 02/20/01 05:02PM
  Dry Gas?Re: Brandon E Brandon E 02/20/01 06:02PM
  Re: Dry Gas?Re: Ron Brown Ron Brown 02/20/01 08:44PM
  Re: Dry Gas?Re: Brandon E Brandon E 02/20/01 09:44PM
  Phosphoric acidRe: Michael Michael 02/21/01 05:02PM
  Re: Phosphoric acidRe: Brandon E Brandon E 02/21/01 08:02PM
  Re: Phosphoric acidRe: Ron Brown Ron Brown 02/22/01 11:01AM
  I thought of another question:-)Re: Brandon E Brandon E 02/21/01 08:23PM
  Re: I thought of another question:-)Re: Ron Brown Ron Brown 02/22/01 11:11AM
