Re: Engine bog and Front Brakes
Fox /
Two things brandon puch bing carbs dont have a mixture screw trust me i've looked My PUch had the exact same problem it turn out that the airfilter was shot after i removed and put a screen over the intake it flies at 40 if thats not it take the carbuerator apart clean the bowl and look at the jet if its clogged use a whire to clean it if it doesnt work you need a new jet . For your brakes wd 40 the cable and brakes alot will engaging break if that doesnt work maybe you have mud in the drum take it apart rinse it out and re esemble it
Thats all i know if it still bogs down yopu can use a 50:1 mix or higher to help that
Fox
  Engine bog and Front BrakesTopic by: Brandon E Brandon E 02/15/01 03:54PM
  Re: Engine bog and Front BrakesRe: Fox Fox 02/15/01 06:58PM
  Re: Engine bog and Front BrakesRe: Rasta Rasta 02/15/01 09:13PM
  Re: Engine bog and Front BrakesRe: Brandon E. Brandon E. 02/15/01 10:29PM
  Hold onRe: Fred Fred 02/16/01 12:39AM
  Re: Hold onRe: Brandon E Brandon E 02/16/01 05:11AM
  Re: Engine bog and Front BrakesRe: Ron Brown Ron Brown 02/16/01 09:33AM
  Re: Engine bog and Front BrakesRe: mike mike 02/16/01 02:50PM
  Re: Engine bog and Front BrakesRe: Ron Brown Ron Brown 02/16/01 05:16PM
  Another QuestionRe: Brandon E Brandon E 02/16/01 03:31PM
  Re: Another QuestionRe: moby moby 02/16/01 05:50PM
  Re: Another QuestionRe: Fred Fred 02/16/01 06:37PM
  Re: Another QuestionRe: Brandon E Brandon E 02/16/01 06:55PM
  Re: Another QuestionRe: Ron Brown Ron Brown 02/17/01 10:27AM
  Re: Another QuestionRe: gimmejimmie gimmejimmie 02/16/01 06:54PM
  what's happened thus farRe: Brandon E. Brandon E. 02/18/01 10:29PM
  Re: what's happened thus farRe: gimmejimmie gimmejimmie 02/18/01 10:40PM
  Re: what's happened thus farRe: Ron Brown Ron Brown 02/19/01 10:36AM
  Re: what's happened thus farRe: Brandon E Brandon E 02/19/01 06:18PM
  Pictures of my machinesRe: Brandon E Brandon E 02/19/01 06:23PM
  Re: Pictures of my machinesRe: Ron Brown Ron Brown 02/19/01 07:00PM
  Adventures of a ConsumerRe: Brandon E Brandon E 02/19/01 08:19PM
  Re: Adventures of a ConsumerRe: Reeperette Reeperette 02/20/01 06:28AM
  Re: Adventures of a ConsumerRe: Ron Brown Ron Brown 02/20/01 10:58AM
  Sorry, RonRe: Brandon E Brandon E 02/20/01 02:31PM
  Re: Sorry, RonRe: Ron Brown Ron Brown 02/20/01 05:02PM
  Dry Gas?Re: Brandon E Brandon E 02/20/01 06:02PM
  Re: Dry Gas?Re: Ron Brown Ron Brown 02/20/01 08:44PM
  Re: Dry Gas?Re: Brandon E Brandon E 02/20/01 09:44PM
  Phosphoric acidRe: Michael Michael 02/21/01 05:02PM
  Re: Phosphoric acidRe: Brandon E Brandon E 02/21/01 08:02PM
  Re: Phosphoric acidRe: Ron Brown Ron Brown 02/22/01 11:01AM
  I thought of another question:-)Re: Brandon E Brandon E 02/21/01 08:23PM
  Re: I thought of another question:-)Re: Ron Brown Ron Brown 02/22/01 11:11AM
