your jet size determines how much fuel mixes with a certain amount of air. On my batavus bronco i use sizes from 56-59. When you put a smaller jet in your moped might go faster and run a little better, but you have to be carefull not to go too low or you will seize your engine since the fuel is the only lubrication.
