Re: Help!!!! with 85 Honda Spree
Fred /
And hot is not lean... A hot engine if anything is running richer... Hotter air is less dense... So there is actually less air for the same amount of fuel.. it's richer.
The screw right above the split at the float bowl would be the idle mixture screw...(which will richen or lean out the idle mixture depending on which way you turn it) and try screwing it in or out an eighth or quarter of a turn at a time to see if it helps.
  Help!!!! with 85 Honda SpreeTopic by: DaveinNaples DaveinNaples 02/13/01 12:49PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 01:06PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 03:03PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 03:10PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 05:54PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 07:03PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 08:39PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 09:23AM
  Re: Help!!!! with 85 Honda SpreeRe: Fred Fred 02/14/01 01:46AM
  Re: Help!!!! with 85 Honda SpreeRe: daveinnaples daveinnaples 02/14/01 09:41AM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/14/01 10:53AM
  Re: Help!!!! with 85 Honda SpreeRe: Fred Fred 02/14/01 12:42PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/14/01 02:15PM
  Re: Help!!!! with 85 Honda SpreeRe: Victor Victor 02/13/01 11:31PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 09:18AM
  Re: Help!!!! with 85 Honda SpreeRe: Victor Victor 02/14/01 12:54PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 02:41PM
