Re: Help!!!! with 85 Honda Spree
Ron Brown /
Dave,
If you have reserve, wait til you are on it, then use the main position as an off position.
If you have no reserve, you would have to find the vacuum line to the petcock and pinch it off or something like that.
Maybe someone with a spree can help.
Same on the adjusting screws on the carb, You need someone with spree experience to tell you which is which but most carbs have at most, an idle speed adjustment and an idle mixture adjustment. A lot of small engines do not have the idle mixture adjustment.
When the engine quits, is there any easy way to get to the flywheel or something similar and rotate the crank by hand to see what it feels like?
Ron
  Help!!!! with 85 Honda SpreeTopic by: DaveinNaples DaveinNaples 02/13/01 12:49PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 01:06PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 03:03PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 03:10PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 05:54PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 07:03PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 08:39PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 09:23AM
  Re: Help!!!! with 85 Honda SpreeRe: Fred Fred 02/14/01 01:46AM
  Re: Help!!!! with 85 Honda SpreeRe: daveinnaples daveinnaples 02/14/01 09:41AM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/14/01 10:53AM
  Re: Help!!!! with 85 Honda SpreeRe: Fred Fred 02/14/01 12:42PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/14/01 02:15PM
  Re: Help!!!! with 85 Honda SpreeRe: Victor Victor 02/13/01 11:31PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 09:18AM
  Re: Help!!!! with 85 Honda SpreeRe: Victor Victor 02/14/01 12:54PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 02:41PM
