Re: Help!!!! with 85 Honda Spree
DaveinNaples /
Thanks Ron, No there were no scuff marks on the piston, and the bore looked real good as did the head, all I changed were the rings and bearings.
The Spree as I'm sure you know is a two stroke.
On the Carb, there are 3 screws..........one near the top of the carb has a spring on it and is the idle screw. Then there's a smaller screw just beneath, that is sort of at the top of the "bowl" and then a larger screw at the bottom of the "bowl".
These two screws are the ones I can't figure out. Do you know which one, or are both used to set the leaness ?
And how can you tell you're not too lean and burning out the engine?
I'll try that first and see if it works, Thanks again
  Help!!!! with 85 Honda SpreeTopic by: DaveinNaples DaveinNaples 02/13/01 12:49PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 01:06PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 03:03PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 03:10PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 05:54PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/13/01 07:03PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/13/01 08:39PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 09:23AM
  Re: Help!!!! with 85 Honda SpreeRe: Fred Fred 02/14/01 01:46AM
  Re: Help!!!! with 85 Honda SpreeRe: daveinnaples daveinnaples 02/14/01 09:41AM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/14/01 10:53AM
  Re: Help!!!! with 85 Honda SpreeRe: Fred Fred 02/14/01 12:42PM
  Re: Help!!!! with 85 Honda SpreeRe: Ron Brown Ron Brown 02/14/01 02:15PM
  Re: Help!!!! with 85 Honda SpreeRe: Victor Victor 02/13/01 11:31PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 09:18AM
  Re: Help!!!! with 85 Honda SpreeRe: Victor Victor 02/14/01 12:54PM
  Re: Help!!!! with 85 Honda SpreeRe: DaveinNaples DaveinNaples 02/14/01 02:41PM
