Moped brace?
Any idea where to find a brace like the one Peter had on the shredped?
Re: Moped brace?
Re: Moped brace?
Isn't it just a tube? Look! It comes with mounting hardware:
Why would you buy this? Honest question. Is it the finish: "It's chromed if you buy it, and painted if you scrounged it?"
Re: Moped brace?
Gunther McCilicutty /
hmmm...chrome. I may buy one now.
not
Re: Moped brace?
I bought a used chrome one for like 9 bux. It was already cut perfectly for my Maxi, so bolt-on goodness was had :)
I don't use it often, but it was too cheap to pass up...that and all the "fitting issues" had been worked through by the previous owner.
I'd never buy a NEW one, tho.
I'm just an opportunist :)
Re: Moped brace?
Weld a pipe on there. It won't do anything if you bolt it on. there's too much play in the bolt on mounting. That weld looks cool anyway.
Re: Moped brace?
I It looks way cooler to take the time to make a frame stiffener and weld it on. Check it out
Re: Moped brace?
Theres not too much play on there if you put it on right. It adds rigidity to the frame.
