i have a 77 Batavus .the idle is real high .any suggestions would help. the idle screw doesn't help Thanks Woody
Woody,
Check free play in the cable at the carb end. If you have to, take off the air cleaner and check that the slide in the carb goes all the way down to the idle screw.
Ron
