petcocks should be interchangable, right?
Re: petcocks should be interchangable, right?
nope, puch, vespa, honda, and i think tomos are, but moby is different.
Cosmo nPuch Stillstolen /
I've got two 78 Puchs that have different petcocks. I guess one is not original.
ive had 4 or 5 different puch petcocks. most are interchangable but some arent. hobbit ones work on puch, but since they are designed to be mounted vertically instead of horizontally, they will probably leak.
if 'by a little work' you mean removing the reserve intake and filters, then yes, some petcocks are sometimes interchangeable.. but that said, you may also find that it mounts in such a way that your frame obstructs the switch or the fuel line outlet, etc. so, generally, no.
Puch fuel valves are easy to get, don't make it any harder than it needs to be.
goddamn. life would be so much easier if they were.
