Puch problems
Andrew /
I got a free puch and its in nice shape... but it needed a new back tire and tube and a clean carb so i did both and while i was cleaning the carb i lose the float needle and when it started i noticed the bike kicked at about 15 mph ( yea i know now its a 2spd) so i change the transmission fluid im not sure how much i put in but im quite sure it wasnt 9.5 oz it was type f so i was either going to need a new carb or a new float needle so i decided to go with the 15 mm bing and here are the list of parts that i ordered from mopedwarehouse
15 mm bing
14 mm intake
hi flow air filter
proma circuit exaust with correct carb jet
fuel filter
back tube
so i finally get all the parts on and it idles at 7 mph so i adjusted the idle screw and it went down to about 5 mph so i took the bowl off the carb and backed out the jet 1/2 a turn and i didnt see any big difference there either so now im stumped and the other thing is it only tops out at 26 mph which is what it did before all those parts listed above... so anyhelp would be great or suggestions
  Puch problemsTopic by: Andrew Andrew 10/01/02 10:16PM
  Re: Puch problemsRe: Dennis Dennis 10/01/02 11:00PM
  Re: Puch problemsRe: InfectedBootSector InfectedBootSector 10/02/02 12:11AM
  YOU DON'T BACK OUT THE JET!!!Re: Chris Rice Chris Rice 10/02/02 12:16AM
  Puch problemsRe: Andrew Andrew 10/02/02 07:41PM
