Re: i just got a tip that my ped has been targeted
don-ohio /
You know, a 12 ga.shotgun shell that has been loaded with rock salt instead of the regular shot is a STRONG deterrent to young moped thieves! Make sure to use it at exactly 30 ft. or a little farther(no closer!).That way the wad won't break their skin,but the rock salt will. Have been there...........done that! Also make sure you clean and coat the barrel after running the `no-goods' off.That salt will cause barrel corrosion for sure! Now if you live in a `mamby-pamby' wishy-washy `treat the criminals with respect' State like California or NY or NJ,MN,etc., DISREGARD this advice as they'll put you in jail and give the criminals visitation rights.Ha! Hope they catch the worthless bums! don-ohio (:^)
