Re: wrecked cables and more ...
Miguel /
Thanks for the advice. You guys are great!
But the problem w/ the clutch wasn't at the handle itself. I could move the handle, but the cable didn't retract at all. It was the cable itself that was pulled tight. I'm not sure why or how. So the cluth is really messed up. I haven't had a chance to look at it yet since then, and probably won't have a chance until Saturday. But I'll order four cables and replace them all in one shot, making sure to lube them good and proper. Two-stroke oils is good? That's all I have right now (other than WD40 and chain lube).
I'm guessing the cables are frayed somewhere. I can only see visually the front brake cable, and that one is COMPLETELY frayed and hanging on only by a threat. Boy, I sure hope the clutch isn't frayed INSIDE the clutch. Would I have to take apart the clutch? How tough is that?
  three problems: petcock, throttle, chokeTopic by: Miguel Miguel 02/08/01 07:30PM
  Re: three problems: petcock, throttle, chokeRe: Ron Brown Ron Brown 02/08/01 08:33PM
  Re: three problems: petcock, throttle, chokeRe: speeddude speeddude 02/08/01 09:24PM
  Re: three problems: petcock, throttle, chokeRe: Miguel Miguel 02/08/01 10:05PM
  direction on fixing throttle?Re: Miguel Miguel 02/09/01 05:55PM
  Re: direction on fixing throttle?Re: mike mike 02/09/01 06:00PM
  Re: Just do itRe: Miguel Miguel 02/09/01 06:53PM
  Just do itRe: Fred Fred 02/09/01 06:07PM
  wrecked cables and more ...Re: Miguel Miguel 02/11/01 04:35PM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 10:04AM
  Re: wrecked cables and more ...Re: gimmiejimmie gimmiejimmie 02/12/01 10:15AM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 10:24AM
  Re: wrecked cables and more ...Re: gimmiejimmie gimmiejimmie 02/12/01 10:09AM
  Re: wrecked cables and more ...Re: Miguel Miguel 02/12/01 03:02PM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 03:12PM
  Re: gas cap problemRe: Dale Dale 02/17/01 05:39PM
