Re: wrecked cables and more ...
gimmiejimmie /
Miguel, Sounds like you're having a run of bad luck. The throttle problem could be in the grip, if you have just 1 broken strand in the cable, it can really bind things up as Ron mentioned. It can start to unravel within the cover. Do as Fred suggested on removing the grip. Then look for any broken strands, and if you have a new one to install, make sure there are no kinks or sharp bends in it when you are routing it.Don't forget to lube it.
The clutch could have the same problem (if it's cable engaged) I don't know how yours works, but if that happens again, remove your spark plug, it will be alot easier to push if you have to. How are things now since you got it home and thawed out?
COME ON SPRING!
gimme jimmie
  three problems: petcock, throttle, chokeTopic by: Miguel Miguel 02/08/01 07:30PM
  Re: three problems: petcock, throttle, chokeRe: Ron Brown Ron Brown 02/08/01 08:33PM
  Re: three problems: petcock, throttle, chokeRe: speeddude speeddude 02/08/01 09:24PM
  Re: three problems: petcock, throttle, chokeRe: Miguel Miguel 02/08/01 10:05PM
  direction on fixing throttle?Re: Miguel Miguel 02/09/01 05:55PM
  Re: direction on fixing throttle?Re: mike mike 02/09/01 06:00PM
  Re: Just do itRe: Miguel Miguel 02/09/01 06:53PM
  Just do itRe: Fred Fred 02/09/01 06:07PM
  wrecked cables and more ...Re: Miguel Miguel 02/11/01 04:35PM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 10:04AM
  Re: wrecked cables and more ...Re: gimmiejimmie gimmiejimmie 02/12/01 10:15AM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 10:24AM
  Re: wrecked cables and more ...Re: gimmiejimmie gimmiejimmie 02/12/01 10:09AM
  Re: wrecked cables and more ...Re: Miguel Miguel 02/12/01 03:02PM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 03:12PM
  Re: gas cap problemRe: Dale Dale 02/17/01 05:39PM
