Just do it
Fred /
Just go ahead and do it Miguel... There is not a lot to it... It is pretty simple.
There are 2 screws that clamp the twistgrip to the bars... take them out and split the housing and you will see where the cable fits into the plastic throttle tube... slip it out... and now you can inspect everything.
Two stroke oil will be fine... don't use too much...smear it on with a finger.... (but clean it all first)
Examine the cable and slide it in and out to see if that is where the resistance is.
The resistance is usually one of 3 spots.... the twistgrip, the cable, or the carb slide.
And just be careful putting it together and don't force anything... and if you have to do it 4 times before it is right.... No big deal.
  three problems: petcock, throttle, chokeTopic by: Miguel Miguel 02/08/01 07:30PM
  Re: three problems: petcock, throttle, chokeRe: Ron Brown Ron Brown 02/08/01 08:33PM
  Re: three problems: petcock, throttle, chokeRe: speeddude speeddude 02/08/01 09:24PM
  Re: three problems: petcock, throttle, chokeRe: Miguel Miguel 02/08/01 10:05PM
  direction on fixing throttle?Re: Miguel Miguel 02/09/01 05:55PM
  Re: direction on fixing throttle?Re: mike mike 02/09/01 06:00PM
  Re: Just do itRe: Miguel Miguel 02/09/01 06:53PM
  Just do itRe: Fred Fred 02/09/01 06:07PM
  wrecked cables and more ...Re: Miguel Miguel 02/11/01 04:35PM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 10:04AM
  Re: wrecked cables and more ...Re: gimmiejimmie gimmiejimmie 02/12/01 10:15AM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 10:24AM
  Re: wrecked cables and more ...Re: gimmiejimmie gimmiejimmie 02/12/01 10:09AM
  Re: wrecked cables and more ...Re: Miguel Miguel 02/12/01 03:02PM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 03:12PM
  Re: gas cap problemRe: Dale Dale 02/17/01 05:39PM
