Re: three problems: petcock, throttle, choke
Ron Brown /
Miguel,
I am guessing that you took the gas cap off during your petcock testing so we can probably eliminate a pugged gas cap vent. If you did not, try it.
You will have to take the petcock off to check it out so you need to catch the gas in something when you do. After you get the petcock off you can check it by just blowing through it in different positions. Depending on the type of seal it uses internally, the seal may have slipped in which case, you have a dud and the flow will be affected.
I am also assuming you do not have mass quantities of crud in the tank.
The choke/no choke problem is because you do not have enough gas to run.
On the throttle problem, there are only three pieces. The twistgrip, the cable and the carb.
You can check the carb by lifting up on the cable where it enters the carb, similarly, you can check the cable by pulling on it where it exits the twistgrip.
The twistgrip should be greased, the cable should be oiled with motor oil and the carb should just be clean. You can squirt WD40 in pinch but it is not the best lubricant. You may also have broken strands in the throttle cable which means you need a new one.
Ron
  three problems: petcock, throttle, chokeTopic by: Miguel Miguel 02/08/01 07:30PM
  Re: three problems: petcock, throttle, chokeRe: Ron Brown Ron Brown 02/08/01 08:33PM
  Re: three problems: petcock, throttle, chokeRe: speeddude speeddude 02/08/01 09:24PM
  Re: three problems: petcock, throttle, chokeRe: Miguel Miguel 02/08/01 10:05PM
  direction on fixing throttle?Re: Miguel Miguel 02/09/01 05:55PM
  Re: direction on fixing throttle?Re: mike mike 02/09/01 06:00PM
  Re: Just do itRe: Miguel Miguel 02/09/01 06:53PM
  Just do itRe: Fred Fred 02/09/01 06:07PM
  wrecked cables and more ...Re: Miguel Miguel 02/11/01 04:35PM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 10:04AM
  Re: wrecked cables and more ...Re: gimmiejimmie gimmiejimmie 02/12/01 10:15AM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 10:24AM
  Re: wrecked cables and more ...Re: gimmiejimmie gimmiejimmie 02/12/01 10:09AM
  Re: wrecked cables and more ...Re: Miguel Miguel 02/12/01 03:02PM
  Re: wrecked cables and more ...Re: Ron Brown Ron Brown 02/12/01 03:12PM
  Re: gas cap problemRe: Dale Dale 02/17/01 05:39PM
