i love muratic acid
cleaned the shit out of my tank
Re: i love muratic acid
i love acid.
cleaned the shit out of my brain.
LOLZZZZ.
Dont get the 2 confused and end up swallowing any muratic acid.
Trevor loves muriatic acid.
If you love damaging the cells in your lungs and the mucous membranes of your nose and throat you should definitely inhale the chlorine gas created by muriatic acid reacting with your tank!
(never do that)
I love powerful corrosive acid because it's how things get done in Gotham City.
I keep the spent acid from a tanking and use it to throw all sorts of rusted parts in. If you want to get a ped down to the metal burn the paint with a torch and the use a paint brush to get the muriatic on. It will totally remove paint from small crevices etc once burned
Ime gona try this this weekend. How burned does it have to be?
triumph3434, basically you have to get the paint surface to crack and allow the acid to seep under onto the metal. Once the acid starts working, it will cause the paint to fall off in chunks because it dissolves a thin layer of metal under it. Do this in a well-ventilated area.
Make sure you neutralize the acid completely afterwards by letting the parts hang out in a bucket full of water and baking soda (well mixed)
Word Pavel!
Mike rock,
That was the first thing that struck my mind when i read the topic and came in to post.
i always keep it around also makes a good bug spray[especially on black widows and scorpions!]
hahaha!
I buy mopeds with rusty tanks just so i get to play with the stuff!
I'm sick, help me!
