Condensor or Coil Problem?
If you have weak spark, how would you know if you had a bad coil or a bad condensor?
Re: Condensor or Coil Problem?
Dennis,it's probably the ignition points that are badly corroded or sticking or gapped wrong. Coils don't go bad very often and condensors are pretty dependable,but points are usually the underlying problem. But if you need guidance,check out Ron Brown's advice on 4-04 on how to check these components. I think it was given this year. If not ,check 4-04-01 postings. I think it's under`my Puch doesn't run',or something like that. Okay? don-ohio (:^)
Will have a look. Thanks Don!
