Trac questions
gimmyjimmy /
1987 Trac Clipper
What type of oil is used in the tranny? the guy has 80wt gear oil in it now.
It has a Mikuni carb, what is the small collar above the throttle slide for? a limiter of some kind?, it restricts the slide from opening fully.
thanks in advance guys.
Re: Trac questions
Chris MWH /
Type F automatic trans fluid is what goes in there. For those of you with tracs That have the Dalim engine that need any clutch/trans parts here is a tip for you. All of the trans parts are identical and interchangeable with the Tomos A3 engine.
Chris MWH
Re: Trac questions
gimmyjimmy /
thanks Chris,
anyone know about this Mikuni collar/spacer thing?
