A3/A35 cross over
Anyone know if you can use the A3 stator plate and flywheel on a A35?
Re: A3/A35 cross over
Tomos has used a few different stators and some tomos engines may have a slightly different bolt pattern for the stator but in most cases they will swap just fine. You'll have to use the coil that matches the ignition setup of course.
BryAn eurism /
I am running a CEV. Had to swap out HT coil and all the bulbs. My horn is way less loud but the transplant works
