Re: Honda mini bush bikes (pics)
Eric Leedy /
If you are talking about the carb bowl over flowing, two things can be wrong. Either the float is stuck/damaged or the gasket around the bowl has dried out and it is running out of there. In any case, remove the bowl and clean the bottom of it inside. There will most certainly be residue from old gas in there you dont need to suck through the jets upon starting it the first time. I would go to the Honda shop and buy a rebuild kit that contains a new gasket and o-rings for the mixture screw etc. It is about $20 and a good investment. Take the bowl off first and inspect the float to see if it is damaged. It will most likely be fine. Put it back together and see if it leaks. If it still does, it may be an adjustment on the tab that pushes the fuel shut off brass stopper into the fuel intake. You will see how it works when you see the inside workings of the float.
In any case, nice pick up! I like the newer parts bike with the larger wheels. You may even want to see if the bigger wheels fit on your rider. They will smooth out the ride a bit.
  Honda mini bush bikes (pics)Topic by: Ian Conlon Ian Conlon 10/10/08 06:34PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 06:35PM
  Re: Honda mini bush bikes (pics)Re: Ian! Ian! 10/10/08 06:41PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 06:43PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 06:44PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 06:46PM
  Re: Honda mini bush bikes (pics)Re: Ian! Ian! 10/10/08 06:48PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 06:54PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 06:50PM
  Re: Honda mini bush bikes (pics)Re: Eric Leedy Eric Leedy 10/10/08 06:55PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 06:58PM
  Re: Honda mini bush bikes (pics)Re: Ian! Ian! 10/10/08 06:57PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 07:00PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 07:03PM
  Re: Honda mini bush bikes (pics)Re: keller_stephen keller_stephen 10/10/08 07:07PM
  Re: Honda mini bush bikes (pics)Re: Ian Conlon Ian Conlon 10/10/08 07:14PM
  Re: Honda mini bush bikes (pics)Re: Zeke Zeke 10/10/08 08:40PM
  Re: Honda mini bush bikes (pics)Re: petewilson petewilson 10/10/08 09:29PM
  Re: Honda mini bush bikes (pics)Re: Nash . Nash . 10/11/08 02:20AM
  Re: Honda mini bush bikes (pics)Re: Nash . Nash . 10/11/08 02:22AM
  Re: Honda mini bush bikes (pics)Re: Steve Williams Steve Williams 10/11/08 05:33AM
  Re: Honda mini bush bikes (pics)Re: Eric Leedy Eric Leedy 10/11/08 05:17PM
  Re: Honda mini bush bikes (pics)Re: Sir Christopher BLKBLK Sir Christopher BLKBLK 10/11/08 08:21PM
  Re: Honda mini bush bikes (pics)Re: Terry Terry 10/11/08 10:17PM
