My friend picked up a jawa and the spark plug cap comes right off the coil wire....anyway this can be fixed without getting a new coil or just get a new one?
When I picked up my Sachs it had no spark plug wire. I just cut a car S.P. wire and epoxied it into the coil. works fine.
if your jawa is anything like mine, there is a screw on the coil that screws into the plug wire, you can simply turn the wire around until it is unscrewed.
just cout the end off the wire, and screw the spark cap on the wire, not too tight, or it will strip.
loook at lights on a moped subject
