Coil
My friend picked up a jawa and the spark plug cap comes right off the coil wire....anyway this can be fixed without getting a new coil or just get a new one?
Re: Coil
When I picked up my Sachs it had no spark plug wire. I just cut a car S.P. wire and epoxied it into the coil. works fine.
Re: Coil
if your jawa is anything like mine, there is a screw on the coil that screws into the plug wire, you can simply turn the wire around until it is unscrewed.
Re: Coil
just cout the end off the wire, and screw the spark cap on the wire, not too tight, or it will strip.
Re: Coil
loook at lights on a moped subject
