Re: Long seat
Zachary Evans /
In theory you could lop off the pipe where the rack bolts on, and actually weld some more pipe onto it, that'd be the right way to do it.
Then like, some wood, foam, and vinal, a couple of mounts welded to the new tube, bolt on a buddy seat.
Or, if you're good, pop apart a longer seat and run bolts through it, or tack some onto the bottom..
I dono, I don't think that it's safe to just extend the free spirit seat, that pan is horribly thin and not superbly constructed, it's really meant to have support under it.
