Bearing keep getting loose
I have a newew style Tomos. ever since its been in an accident, the bearing nut keeps coming loose from the rear wheel. This causes it to wobble. When I tighten it, it comes loose again. I think it is stripped. is there anything I can do or do I need to replace something in the wheel. I do not want to go out and buy a new wheel unless I have to. These Tomos wheels are pretty pricey I hear. thanks
Re: Bearing keep getting loose
You can replace just the axle, costs about $8.50 - isn't too all-fired hard to do.
While yer in there, check the bearings just in case, they're fairly cheap to replace, and might need it if they've been kicked around a bit, then again, might not.
Should not need to replace the wheel itself, no.
-T
Chris MWH /
Trike is right, May even be cheaper than that if just the nut is stripped.
Chris MWH
