hobit carb problems
after I warm my Hobit up and the choke comes off the motor dies. Can't get it started unless it's choked. But it won't run right choked. I've tried all adjustments. No luck. Any ideas?
Re: hobit carb problems
Doc Holliday /
Clean the carb, brother. I know from bitter experience that these PA50 beasts will not run with a dirty carb. Soak it in carb cleaner, blow it out with compressed air. Make sure you note where all the parts go before you dissassemble. Pay special attention to the jet and various airways.
Doc
