Fuel Line Switch
cyber freak /
I have this Honda NC50 and have been fixin it up 4 a couple years now and i finally put gas in it and the little switch to turn the gas on or off leaks.
Does anybody know where i can get a new one. Or can i just get an adapter to hook the hose directly to the tank?
Re: Fuel Line Switch
Let it leak for now and get it running.
If it turn out that it costs $300 in parts to get it running ..then fixing the petcock wouldn't be worth it.
By the way.. What is an NC50?
I don't think I've heard of that one.
Are you in the US?
Almost any Honda sold in the US in the last 15/20 years will have parts available at a Honda dealer.
cyberfreak /
Its an 84 NC50 Express and wont it blow up if i let it poor out gasoline?
I thought was more of a drip, not a stream of fuel.
A minor drip usually is no problem.
Only you can decide if it is unsafe.
You can probably buy a new petcock for $20 from a Honda dealer.
Or maybe it just need an o-ring?
Re: Speaking of Fuel line
Reeperette /
Just worth a mention, for all that clear fuel line seems preffered in moped construction, I found that windshield wiper tubing makes an excellent replacement that lasts much longer than OEM original, as well as being inexpensive and readily available at any auto shop.
-Ree
