tail lights fa 50
Can i use a front indicator for the rear in a fa 50??? they look the same??
Re: tail lights fa 50
what? do you mean can you use the bulb for a turn signal in an FA50 taillight socket?
it will work, but you either will only have the taillight, or a brake light, since the turn signal bulb is single-filament. unless of course it's like my express was, where the person was using 1157's for EVERY bulb on the bike.
does it fit the socket? does it come on when you turn the key? trying it wont damage the bike, just see if it works. is there one filament or two? i'd use an 1157 for the brakelight. you can get them anywhere. i even see them at gas stations a lot.
