Moped won't start
I have a 2003 midwest cosmo that was runing now
it will not start. I pulled the spark plug it's geting spark.
Also what kind of oil do i use do i have to mix it with the gas?
Re: Moped won't start
§ćŗάτçλmªřċ • /
has it been awhile since you last started it? the carb may need cleaning, but that's just the primary culprit.
pretty much any 2 stroke oil you can find at an auto parts store (brace yourself for blank stares or worse if you mention you have a moped) at 3 oz per gallon of gas premixed in a separate gas can should suffice. some folks prefer synthetic oil but it's not quite as easily obtainable.
good luck.
~marc
It's been about a week since last started.
Leon Swarmer /
changing the plug is always agood first step. what color is it around the gap area? Dryish or oily?
it gets good spark. It's dry around the gap.
