Please Help with Vibration Noise
I've got my Snark running perfectly except for a horrible metal vibration noise which appears to be coming from the front of my bike or near the engine. I have taken off fenders, tightened every bolt on that bike, put rubber underneath the gas tank, pulled wheels, and I just can't get the noise to stop or tell where it's coming from. It starts to make the noise at around 15 mph and then will eventualy stop when I reach 25 mph. But for that 10 mph period, the noise is terrible and sounds like a loud metal on metal vibration.
Any idea as to what it could be????
TIA,
Larry
Re: Please Help with Vibration Noise
Matt Lorence /
Bearings on the rod going bad?? Maybe your piston is rattling around a bit. My old LT80 fourwheeler sounded bad like that, cleared up after an engine rebuild.
Matt,
I think I may have gotten rid of the noise tonight. I replaced the rear part of the frame and the noise appears to have stopped, at least for now anyway. Hopefully, this did the trick.
Thanks for the advice.
Larry
Matt Lorence /
well, good luck with it.
mopedmaniaclt /
make sure you have enough oil lub
