WARNING !
Fred /
Do NOT play with your oil mixture as a "tuning tool" !!
(unless you want to seize your motor)
I wouldn't run that PA at any less than 3 oz oil per gallon of gas (43 to 1)
Frankly .. I will be running 32 to 1 from now on in mine (4 oz oil per gallon).
You probably should too.
PA50I's need several small items to get speeded up.
If you use the 'search' .. you will find out what they are.
  1979 Honda PA50 acting weirdTopic by: J.Frank T. J.Frank T. 09/15/02 10:52AM
  Re: 1979 Honda PA50 acting weirdRe: J.Frank T. J.Frank T. 09/15/02 05:39PM
  Re: 1979 Honda PA50 acting weirdRe: Fred Fred 09/15/02 06:50PM
  Re: 1979 Honda PA50 acting weirdRe: mopedmaniaclt mopedmaniaclt 09/16/02 12:30AM
  Re: 1979 Honda PA50 acting weirdRe: J.Frank T.-answer to Fred J.Frank T.-answer to Fred 09/16/02 08:31PM
  Re: 1979 Honda PA50 acting weirdRe: Fred Fred 09/16/02 09:41PM
  Answer to FredRe: J.Frank T. J.Frank T. 09/18/02 10:55AM
  Re: 1979 Honda PA50 acting weirdRe: J.Frank T. J.Frank T. 09/20/02 04:02PM
  Re: 1979 Honda PA50 acting weirdRe: J.Frank T. J.Frank T. 09/24/02 10:16AM
  WARNING !Re: Fred Fred 09/24/02 09:02PM
  Re: WARNING !Re: JD JD 09/24/02 10:21PM
