idea for Kinetic
I've been thinking- the kinetic has a head gasket because of poor machining. If I took the head and the cylinder and flattened them, would I be able to eliminate the gasket?
I'm thinking of using valve-lapping compound on a flat piece of tempered glass (if I can find some), to level them both. Do ya'll think this would work?
Or would I run the risk of making a bigger gap if one piece, either the head or the cylinder, is a little off.
Re: idea for Kinetic
chuck russo va /
i did that too my head on my tomos after i lightly milled it,
it worked fine, i just used a regular window pane from that hardware store, i think it was like 3 bucks for a 12in x 12in piece
