BiTurbo ping
Danko Craig /
I have a tomos targa lx with a biturbo. I get a small ping sound. It's definitallt the exhaust vibrating on the block. I do get a bit of oil leakage from the port of the block but onl a couple of drops a day. If I grab the pipe it does quiet. I can't get the nut to go on ant tighter with out the feeling I'm going to breack something. I check it every couple of days and they don't loosen. But it's still there. I put the biturbo on the second day I had it and can't remember what it sound like with the stock exhaust. Is this normal? Does anyone else experiance this? Any suggestions?
Danko
Re: BiTurbo ping
Dude, it's just air bouncing around in the expansion chamber of the pipe. They all sound like that.
Re: BiTurbo ping
Danko Craig /
Thanks man. I wanted an easy fix. How do I do less thean nothing?
Re: BiTurbo ping
There's nothing to fix....That is just how it is. Doesn't your moped sound tough now?
Re: BiTurbo ping
TJ Miller /
do you have an exhaust gasket on there? i recomend changing that gasket when you changed your exhaust over.. check it out.
Re: BiTurbo ping
Danko Craig /
I put a new gasket on.
