cruise control
i go on very long trips and i just get tired of holding my trottle so i have devised one method of cruise control i know some of you would say oh thats dangerous but that how i roll and once you get top speed riding with no hands is no prob you can lean to avoid things in the road. but what i do is i find a very thin chain drill one end close to my trottle on my handlle bars on the other end hook a metal pin then i pull the trottle wide open and drill a hole trough the grip and down trough one side of the handle bars once you get on a long stretch i slid in the pin. cruise control.
Re: cruise control
Or you could just have a sticky throttle like me. Safer because you don't have to pull the pin off, just pull the throttle back when you need to.
Re: cruise control
you really shouldn't run a 2-stroke engine at a constant rpm, safety for me isn't the issues, it's engine wear
Re: cruise control
jusst undo the spring that gives your throttle tention
Re: cruise control
Just use as rubber band.
Re: cruise control
sticky throttle ftw. till u can't push it down....
Re: cruise control
Jason Jason Bobason /
If you get rid of the spring you won't be able to push the slide back down.
Re: cruise control
not that spring.
the one beside your grip
Want to reply to this thread?
