Re: cheap or free ways to get more omph out of ur
[[ Linda ]] /
Is your carb clean? Fresh gas? Clean fuel tank? Good compression? Exhaust port/exhaust free from carbon buildup? Good strong spark? No air leaks? Everything properly lubed, filled, and screwed on? That's the kind of stuff you should start with if you want the stock power back. If you have questions about any of that stuff, just ask in the repair forums (try to put "QT50" in the title ... you'll get more help and others will be able to search for it easier later).
