Rockin! I will pick up a fuse after work and try it. I looked at the brown fuse that was already in there and it looked ok but maybe i didn't look close enough. I will try contacting the local dealership if that doesn't solve the problem. Thanks everybody for being helpful.
Side note: There is a small black wire hanging out with a round connector under the seat and a small black wire with a squared connector under the spedo. I thought these might have been the problem, but I cant find anywhere they would plug into. I figure now that they are used for testing purposes. Am I correct in that assumption?
