Re: Tomos Warranty?
marvyhi /
Hi Chris, your problem is a common one. The main fuse burned out. My guess is you are running a 7.5 amp fuse. Change out the fuse to a red one which is 10amps. The fuse is located under the left side cover. Take the cover off and you will see a lot of wires. Look for the fuse holder. Change out the fuse and everything should be alright.
