HELP my Garelli Rally's Choke is Stuck
Hi My Garelli Rally Sport choke is stuck I drove it home from the guys house that I bought it from and now it looks like the choke is stuck. Can anyone help me...
Monica
Re: HELP my Garelli Rally's Choke is Stuck
twist the throttle all the way out, the choke should click off. if that doesn't work, you'll have to pull the carb apart and make sure everything is where it needs to be.
You must pull all the way back on the throttle to release the choke. If this does not open the choke, remove the air filter cover, and the air filter, and pull back all the way the throttle cable, and look at the carburator once you have the air filter off to see why the arm is stuck that releases the choke. You might be able to pull on the throttle cable housing near the carburator to release the choke. If you can do that to release the choke and only this will work, that indicates your throttle cable needs to be tensioned.
You can push the lever to the side a little bit and it will pop up.
