Magnum gas tank mounting
What's a good substitute for the rear rubber mounts? Mine are missing so I don't know what they look like.
Dan
Re: Magnum gas tank mounting
a tampon.
By the looks of your profile shot you prob have a few extras layin around could you send me one
At Home Depot or Lowes you can buy two different size of clear tubing. Take a section of one tube and put it inside a section of the larger tube. One inside the other. Slip it over the pegs or whatever you want to call them and the fit the tank over that. Sorry but I forgot the exact size of the tubing. You will have to figure and measure it yourself
if you have a friend with a magnum chances are you can make a polyurethane copy of it. make a polyurethane cast of it then fill that cast with poly urethane
Thanks for the ideas. I'll have to go the home depot route, no Magnums around to get a copy from.
Want to reply to this thread?
