You should have posted this before you took a wrench to it.
Did you label all the parts and put them in baggies, take photos of every piece while it is still togther.? In a month it will be hard to remember, harder as the time gets away.
If you run across another that you can leave together as a reference it could be a good idea. then you can rebuild it later. or you can use it for a parts supply if needed.
