Early 60s Honda c100
Hello, does anyone know where to find a manual or just a wiring diagram for an early 60s (62/63?) honda c100. I'm beginning a restoration on a running and mechanicly sound cub. Anyone with valuable info on this subject would be huge as this is my first restoration. Any info on finding parts (wire harness) would be rad too.
Thanks
Dennis
Re: Early 60s Honda c100
<www.dratv.com> has wiring diagrams, the c100 is same as older
6v c70. He has many parts you can use but is a major asshole if
you question him. Watch freight charges, he once billed me $60
to ship 2 passport tires ($40). His wife fixed it but he continued to
harass me after the refund. (But he has cheap parts)
Many parts I get overseas through E-bay, type c100 into search.
contact the seller with a list of all needed parts and ask for a total
cost with shipping, it will save you $. Shipping takes 4-6 wks.
Sorry but I didnt get a name from you. Who has wiring diagrams and cheap parts?
Dennis
Oops. <www.dratv.com>
For some reason when I link it it erases, Its dratv with the www and
the .com
All those 6v Hondas share components, this diagram should be
very close to yourshttp://us.st12.yimg.com/us.st.yimg.com/I/dratv_2010_116703684
You have no idea how huge this is for me! Thanks! Couple of questions though. What is the combination switching diagram? Do you know if the c100 has the same color coding? What is the first thing in line from the battery(has the + and - running through it)? Just a plug? Thanks again.
Dennis
Every 6v honda I've worked on has had the same colors. That is a
plug or grommet in the picture, I don't think yours will have it.
The combo diagram is basicly showing you what happens inside the
ignition switch, it will make sense if you stare at it long enough, if
you suspect a bad switch you can test it using the diagram.
Good luck!
