Info on the bing 18 carb from a korado
Does anyone have any info on this carb? Is it really an 18mm? Are the jets the same as the standard bing jets that are found in the carbs from maxi's? About how many turns out should I try setting the mixture screw at. Right now my ped will only run if I hold down the choke.
bump
Anyone?
Re: Info on the bing 18 carb from a korado
I had the same prob with my 18 bing too. The carb is only 14 mm, and it's attached to a 14mm intake. The 18mm jets are bigger, and harder to find. I ended up ditching my 18 and putting a 14 on it. It ran great with a 14
Want to reply to this thread?
